car turns over but wont start
have a 97 civic and it wont start its turnin over grand but wont start i have no spark or fuel can any one help me thanks
When you turn the key to ON(II), does the CEL remain ON or does it turn OFF after 2 seconds?
Also check whether the important ground wire attached to the thermostat housing is loose or corroded. If so, clean with steel wool and then reattach tightly. |
wrong section
honest question (for research purposes): was the title of the section misleading to you? |
Maybe a mod or admin will move the thread to the General Tech section.
Originally Posted by RonJ
(Post 616724)
i proposed a solution (slightly altering the section's name) to this ongoing problem and kevin told me in his opinion the title of the section is fine and that newbies need to learn what section is what... well that's called circular reasoning, and you can't solve the problem like that. OP: do you think a better name for the section would have deterred you from posting this in this section? |
Trust, just volunteer to be a mod. Then you will likely have more influence on making site changes.
(Post 616727)
kev said the forum doesn't need anymore staff right now, and it's pretty dead around here so there's nothing to do |
Well, I think there must be an opening for an Active Mod, which is what you'd be. The relatively Inactive Mod slots are definitely filled.
the engine man light stays on but there is a green light wit a key flashs once then its off but when i turn off the key the green light flashs 5 times
