02 sensor
as i took the heat shield off my exhaust manifold the other day, i had to unplug what i think was an 02 sensor plug. so i unplugged it, plugged it back in.. and now i have a CEL on. got it check out and as i thought... 02 sensor. is there anything harmful that could happen if i dont replace this?
Yea, your gas mileage will probably be affected as the o2 sensor basically tells the ecu the A/F ratios, and to either add more gas or lessen it. Now, if you don't ever fix it, yea potential problems could arise. If you are saying something like that you won't have the money for the next two weeks, then you should be fine. Just don't ignore it forever.
addiction2bass
Aug 14, 2008 09:53 PM
fglaustin
Mar 27, 2008 08:29 PM
Vox1
Oct 14, 2007 12:29 PM
00sithrottle
May 12, 2005 10:25 AM
