96 LX with cracked manifold.
I have been trying to keep my vehicle as stock as possible. Now I have a cracked exhaust manifold. I see there are a lot of header units available. I only see one problem with using any aftermarket header on this car. The o2 sensors. The first one is for balancing the air/fuel ratio. The second one is for determining if the cat is functioning. Well since the cat is part of the header on this year and model there will not be one and an engine code will be thrown even if a dual o2 sensor unit is used. How do I set up the system to not throw a code?
RE: 96 LX with cracked manifold.
title says 96
If you're trying to keep it stock, you MIGHT be able to pick up an original manifold from someone who has replaced theirs with aftermarket. Any 96-00 DX/LX mani should work.
http://cgi.ebay.com/ebaymotors/92-95...11329834QQrdZ1 $10.
http://cgi.ebay.com/ebaymotors/Honda...36172325QQrdZ1 23$
http://cgi.ebay.com/ebaymotors/92-95...35627334QQrdZ1 $10
i thought that was on just cars with california emissions?........or is it on OBDII cars?>.....either way its a D series motor, so ud just need an in line catalic converter.....you can get those cheap too..
