AEM SRI?
Old Jun 22, 2007 | 09:40 PM
Anthony's Avatar
Default AEM SRI?
I just had an AEM SRI installed on my 95 honda civic dx, 4dr. It is quiet that is a good thing. It does make a whistling noise from the amount of air it sucking up. It does seem like more better throttle response, but only a slight jump in performance of the car. I suppose the next thing to do is to get a cat back exhaust. The stock exhaust is horribly small, the piping. Should i be able to hear that whistling from the intake?
Old Jun 22, 2007 | 09:41 PM
ej6buddy's Avatar
Default RE: AEM SRI?
whistling is normal, catback could be your next step if you want
Old Jun 22, 2007 | 10:01 PM
Anthony's Avatar
What brands do you recommend and a good size for the exhaust.
Old Jun 22, 2007 | 10:14 PM
my05civic's Avatar
get 2" piping. go custom exhaust. read the exhaust faq for exhaust ideas...
i am well aware that 2" is pretty small as well, probably not a huge increase on the stock piping - whatever it is right now, but your car has a d15 and it doesn't produce that much power to justify any piping larger.
Old Jun 22, 2007 | 10:30 PM
Anthony's Avatar
Yeah those damm D15's, stuck with it now. So you say anything bigger then 2" would be a waste, because there isnt enough power anyways. What would happen if i has one that was bigger then 2"? Im not expecting alot out of this engine, but whats really the best i can aim for performance wise on a D15.
Old Jun 23, 2007 | 04:49 AM
s2000gtx's Avatar
just do the basic Intake, Header and Exhuast if u want to do performance wise on the D15. also a on ur instake try one of those K&N Filter they say that u get better result from it. and that about all u can do i guess.
Old Jun 23, 2007 | 07:25 AM
my05civic's Avatar
the d15 has ~102 HP. depending on your engine condition, tranny condition, conditions of atmosphere, chances are you'll see less than the 102. probably 90 ish (if anyone has a better estimate, correct me). with 90 hp, daily driving, you will see a loss in low end power if you get something large. 2" - 2.25" is often recommended for cars with a minimum of 100HP, and the 90 HP that you have, you'll probably be safe getting the 2". with IHE, you'll gain the ~10HP and then you'll be over 100 HP, thus the 2" will be perfect. if you plan to turbo though, it's an entirely different story.
Old Jun 23, 2007 | 08:14 PM
Anthony's Avatar
Alright thanks for the info, that really helped out. Ill go with the 2" exhaust for the car.
Old Jun 24, 2007 | 04:10 PM
phsballer123's Avatar
i would get a header first... your intake gives the motor air... then the header is what puts the air through the exhaust. i mean i guess it doesn't matter what you get first as long as you get both eventually
Old Jun 24, 2007 | 04:19 PM
ej6buddy's Avatar
ORIGINAL: phsballer123
just think of your motor as an oversized leave blower with combustion. both ends of the motor are restricted, so you'll see a fairly equal increase between the two.
