AHHH! bolts
Old Aug 28, 2006 | 11:48 PM
frelly's Avatar
Default AHHH! bolts
got my apexi ws2 today...looks gorgeous
was all set to install...and as im sure has happened to some of you, the bolts stuck something feirce
so i drenched in wd40...waited 5 minutes tried again, nope
went and got some pb blaster bolt remover, nothing
pulled out the compressor and the air socket wrench, still nothing
impact gun, nothing
got dark and now im just pissed
should i hack the bolts? or see if a muffler shop has any tricks and drive home cat-back'less?
Old Aug 29, 2006 | 07:15 AM
Default RE: AHHH! bolts
which bolts are you referring to, the ones holding the stock cat-back to the cat? Those are infamous for being very stubborn. We had to just hack mine off with a cutting wheel. Some may disagree, but I suggest replacing all those stupid spring bolts with regular heavy duty bolts/nuts. I re-used my spring bolts the first summer I had my cat-back on, then the next summer I replaced all of them with regular nuts and bolts, and the sound of my exhaust was noticably better.
Just a suggestion..
Old Aug 29, 2006 | 07:29 AM
Froznface's Avatar
Are you looking to get headers and high flow cat also? If so, just wait. You can drop the whole old exhaust without having to undo any bolts (except for a couple that may hold the header onto the frame). Then you're all set. Otherwise, hack those suckers off.
Old Aug 29, 2006 | 10:52 AM
ya just cut em off and replace em.
i had to do that on my old 86crx.... well not realy cut them they snaped in half when i was cranken on them.LOL
i got lucky when doing my 99EX header. bolts where rusted realy bad BUT came off easily enough.. BUT the guy also said the exaust was just redone.
Old Aug 29, 2006 | 02:23 PM
finalimpact's Avatar
ORIGINAL: Forty04
Just a suggestion..
i to hate the spring bolts but they help to releve tension on the exh system when the engine moves. if you intend on doing away with the spring bolts be sure to have a flex pipe added into the system for the added insurance agains cracked headers, exh piping etc.....
Old Aug 29, 2006 | 02:25 PM
ORIGINAL: finalimpact
ORIGINAL: Forty04
Just a suggestion..
I use those big long hangers that move pretty freely, but when I upgrade to my high-flow cat, I plan to put a flex pipe in as well. Good thinking
Old Aug 29, 2006 | 02:48 PM
my last crx didnt have spring bolts or the flex pipe. my header cracked as well as the exh piping right after the weld behind the cat......it was gay
Old Aug 29, 2006 | 03:41 PM
ya you gotta have that spring bolts....
when i redid my 86crx pipe the flange was so rusted out i ended up droping the pipe off the manifold which snaped both bolts... droped the pipe and welded it up from the inside and then just used some new bolts BUT i still used the factory springs inbetween. seemed to work just fine! stoped leaking.
my only problem was from my clamped pipe that i used to go over the rear axle and conect to the good old fart cannon... the pipe kept bending and the buyer told me it just came loose one day.LMFAO
tho it was still hangen by the hanger so he just had to slap the pipe back on and crank down the bolts even more on the clamp.
ya ya .... i know fart cannon... i was new to these hondas and it was a old 86 crx so NOTHING SPECIAL.LOL i was gonna put a cheap @ss wing on it to..... JUST TO BE FUNNY of course, never did tho. but i did buy the used turd... i figure ill slap it on something realy stupid to be funny
Old Aug 29, 2006 | 03:44 PM
civicexracer's Avatar
dremel is ur friend
Old Aug 29, 2006 | 03:54 PM
a ya dont even need that... just snap them suckers! bust out the MANLY BREAK BAR and bust them suckers!
i dont use the impact gun for anything that rusted on anyways. just bust out the socket and the good old 2-3ft long break bar!
my four favorite tools...
4. break bar
3. adjustable wrench
2. vis grips
1. HAMMER EVERYONES POPULAR TOOL!
