Dually
Old Feb 7, 2005 | 02:54 PM
Remmy's Avatar
Default Dually
Im going to dual my civic out wiht 2 mufflers... kinda like a mazda 6. Ive recently seen under my car and saw that it will accomodate a second muffler. Its in the wanted section too. Also, any body know where i can find a bumper that looks exactly like a stock but it has another opening for a 2nd muffler? Or can my stock bumper be modified with some body fil or something?
Old Feb 7, 2005 | 03:20 PM
slvcivic00's Avatar
Default RE: Dually
Some Mazada 6's have V-6 engine's, therefor they work well with two mufflers, having duel exhaust, one for each header. Two 3 into 1 headers going into duel exhaust. Having duel exhaust on a 4 cylinder single header civic is pointless for flow. You will have to split the single exhaust into two pipes at the end. But if you are going just for looks than go for it. But don't do it if you are trying to get any performace out of it.
Old Feb 7, 2005 | 03:47 PM
Remmy's Avatar
Default RE: Dually
Yea i figured maybe a possible some and a most likely not but if you think about it, itll look real good. But Im upgrading to 2.5 pipes so 2 stock 1.5 pipe mufflers will help.
Old Feb 8, 2005 | 12:16 AM
slvcivic00's Avatar
Default RE: Dually
I am still not 100% sure this set-up will increase horse power though, it seems to me that most of your exuast will want to travel out of the right hand muffler since it is the easiest and most direct way for the exhaust to flow out of. The exhaust would have to travel way over to the left muffler from the split in order to work, and that is way out of the way for the exhaust to flow. But let me know if it works for you and how it goes, and good luck.
Old Feb 8, 2005 | 12:27 AM
sacicons's Avatar
Default RE: Dually
itll probably help a little over stock, but it will probably hurt power compared to a normal aftermarket exhaust. but, with FI, it could make a difference.
Old Feb 8, 2005 | 08:35 AM
Remmy's Avatar
Default RE: Dually
well at one point in the middle of the car the pipe does run center under the car. I dont see why it would have to go out of its way... but this idea is mainly for looks, it is now depending on if I can find a stock like bumper that will take to tail pipes.
Old Feb 8, 2005 | 11:15 AM
sacicons's Avatar
Default RE: Dually
that is key. it has to look like its supposed to be there.
Old Feb 8, 2005 | 01:14 PM
Remmy's Avatar
Default RE: Dually
odly enough it does.... why do you think honda would do that? perhaps they were planning a dual exhuast but never realeased it or did they do that for expandability? still looking for stock like bumper [&:]
Old Feb 10, 2005 | 08:16 AM
Roost3r's Avatar
Default RE: Dually
in my opinion...the only dualed 4 cyl. should be a honda 2000.your much better off with a aftermarket single then tryin to dual... hehe but do what youd like.
Old Feb 10, 2005 | 08:24 AM
Remmy's Avatar
Default RE: Dually
mainly looks ya know? it would look cool tho. I though s2000 were sixers?
