Guess my horsepower please??
Old Feb 18, 2007 | 08:16 AM
telecasteriv's Avatar
Default Guess my horsepower please??
I own a 2000 Civic Sedan with the 1.6 Liter engine. I've added a cold air intake, Arospeed race headers (took off cat) and Borla cat back exhaust. I'd like to be able to tell my buddies how much horsepower I have but don't want to get a Dyno. Honda says the 1.6L started at 115 hp. Am I pushing 150?? Can someone estimate how much horsepower I now have.
Thanks
Old Feb 18, 2007 | 08:19 AM
D16Punk's Avatar
Default RE: Guess my horsepower please??
Unfortunetly you're not near 150. The only real way to tell is to have the car dynoed. What engine do you have? Because the only one that I know of during the 1996-2000 generation of civics the only one to come with 115 hp is the HX.
Old Feb 18, 2007 | 08:47 AM
WhiteRabbit1021's Avatar
I wish I/H/E gave you 35HP...
I'm guessing you'd be lucky to be around 120 now... but you might want to get a few more guestimations.
Old Feb 18, 2007 | 11:33 AM
ej6buddy's Avatar
well, even if some paper says that your engine has 115hp, it doesn't because of lost compression and the condition of a nearly 7 year old motor with probably 100,000 mi. your car probably had around 105 or so to start with, after I/H/E, you're probably around 110 to 115 if you're lucky
Old Feb 18, 2007 | 11:58 AM
Street Sniper's Avatar
Here's a little perspective from another guy...
Jdm d15b
59300 cam/valve springs retaners
AEM cam gear 3 degr retard
head milled .025
cometic headgasket
ARP headstuds
pulleys
Intake
Edlebrock header
Test pipe/ 2.5 inch exhaust
KMS stage 2 p&P
skunk2 intake manifold
hondata manifold gasket
60 mill TB
Msd sport compact ignition/external coil
Walbro 255 Fuel pump,pressure regulator, AEM Fuel rail, Rc 310 cc injectors
11lb flywheel
act 6 puck clutch/ si transmission
hondata s200
Add that all up and what'dya got? 125.6hp and 107.7lbs of tq. No compression = no Hp.
I would say that you are nowhere near 150.
Old Feb 18, 2007 | 12:00 PM
ej6buddy's Avatar
why did you build up a d15b? any reason?
Old Feb 18, 2007 | 12:07 PM
I guess I was way off. A guy can dream can't he. It's my first Civic and I wanted to do everything I could to boost horsepower without adding a turbo or supercharger. I've noticed it's definitely quicker. Anyway........... thanks for all the feedback.
I suppose I'm ready for the new 2007 Civic SI.
Old Feb 18, 2007 | 02:13 PM
ORIGINAL: ej6buddy
Just for the recoed, this isn't my motor; it's another guy. I was just making a point how hard it is to get to 150 NA. But as for the JDM D15, it has a better r/s ratio and a hotter cam than the usdm counterparts.
Old Feb 18, 2007 | 03:48 PM
ej6buddy's Avatar
yeah, i know, that's the same for all jdm counterparts, should have at least started with a z6 or a y8 to build off of
Old Feb 18, 2007 | 07:18 PM
Stumasters's Avatar
Man, I have to get a new engine, lol.
I want one of those nice DOHC stock JDM's that push almost 200hp, wish I had the cash for that.
