Header Installation Bolts
Old Jun 28, 2006 | 11:32 PM
ivtec's Avatar
Default Header Installation Bolts
Okay well I've read some post here and there but I got my megan header in and goign to install it in the morning, heres my first question. Do I honestly need a T-wrench? I mean I know its recommened but I have no dough right now not even for a 15 dollar one lol.
Is there a way to tighten it and come close to a t-wrench with jsut a rachet? Liek you know on spark plugs 2/3 turn or whatever crap.
Thanks for the help in advance.
Old Jun 29, 2006 | 12:34 AM
D16Punk's Avatar
Default RE: Header Installation Bolts
All I needed to put on my header was, a socket wrench, 10 - 13 or 14 mm sockets, adjustable wrench and alot of wd 40.
Old Jun 29, 2006 | 01:45 AM
ivtec's Avatar
yeah i was jsut thinking the same lol of course bolting from inside out and making sure i dont over tighten.
Old Jun 29, 2006 | 09:29 AM
D16Punk's Avatar
You shouldn't have a problem with the over tightening I didn't have any problems with it. The only thing that gave me a problem was getting the stock exhaust manifold out of there. Putting the header in was cake after that.
Old Jun 29, 2006 | 10:37 AM
riceburner700's Avatar
yeah the stocker is gonna be the biggest hurdle to get over
Old Jun 29, 2006 | 02:06 PM
Remmy's Avatar
I think you do need a t wrench. Because fi you dont do it tight enough, your gasket is gonna blow.
Old Jun 29, 2006 | 11:46 PM
ivtec's Avatar
well i guess i did go ahead and use a T-W but after installtion of the megan header I kept heaing rattles, you know kind of like a metal rattling sound, is that normal? Also I checked all the bolts everything was tighten up.
Old Jun 30, 2006 | 08:06 AM
check all your heat shields
Old Jun 30, 2006 | 09:46 AM
D16Punk's Avatar
ORIGINAL: ivtec
I had rattles when the crossover into vtec occured, because I didn't have the springs on the bottom bolts connecting the bottom header pipe to the exhaust pipe. Once I got the springs put in, it went away.
Old Jun 30, 2006 | 04:33 PM
ivtec's Avatar
by the way are you guys using the stock cat or a high flow test pipe?
