header shield?
If I'm correct, the heat shield over your stock header is good toleave oncause it keeps the heat from the header from getting to the engine bay as much, which would cause a loss of power. With an aftermarket header, the heat shield isn't needed because the headers are made of better metal that doesn't heat up as much or as fast as your stock one does.
ok, im gonna take it off but the bolts are completly rusted on the bottom, is there a better way to get it off, the outer edges are striped fom the rust on the bolts.
i couldnt get mine off.. they just striped the heads off...
i ended up when removing my stock header i just left the shielf on and twisted the shield back to get to all the bolts to remove it....
also would i be able to find a haynes manual at any local autozone?
and i heard that you can rent torque wrenches and get the money back when you return it, i could go down and check for myself but its closed now and im curious.
