Help! P0420 code
I replaced the cat and both o2 sensors and cleared the codes and I am still getting the p0420 code on my 99 ex coupe. She is also bogging out on me every morning when I leave the driveway. It does this when I go into second but if I push the clutch in and rev it it goes away. I am trying desperately to get rid of this.
Please help!!!!
Please help!!!!
If your primary O2 sensor is located in the exhaust manifold, then it is as upstream as you can get. If not, you should theoretically not have to look upstream of the primary O2 sensor as P0420 is determined by a comparison of readings from the primary O2 with those from the secondary O2 sensor.
ptw711
Mar 3, 2013 01:36 PM
