Idle Control Solenoid/ Skunk 2 manifold ??
Old Jul 10, 2006 | 10:50 AM
Fiasco's Avatar
Default Idle Control Solenoid/ Skunk 2 manifold ??
Last weekend I gave my 99 EX quite a push by installed the Skunk 2 Manifold & TB, Hedman Header, lightweight flywheel, full MSD ignition system, stage 2 clutch, and a cheapo ebay cold air intake.
Car responds awesome, but alas, check engine light, and the car's idle "coughs" after about 15 minutes when its warm.
I threw the Idle Conrol Solenoid code when I scanned...I guess my question is does this solenoid need to be changed out when upgrading manifolds? Or should I be looking at something else?
Thanks
Old Jul 10, 2006 | 11:33 AM
riceburner700's Avatar
Default RE: Idle Control Solenoid/ Skunk 2 manifold ??
not all the time, just pop it off of there and look at the screen, it should have carbon black stuff built up onto it. Just clean it off and out if you can with like some carb cleaner or something like that and the code should go away...
9 times out of 10 they are just clogged to much
Old Jul 10, 2006 | 12:00 PM
Fiasco's Avatar
thanks man, I will try it out!
92civc4dr
Dec 21, 2009 04:42 PM
marquez0721
Sep 19, 2008 07:19 PM
yerryjusko
Jun 6, 2006 12:36 PM
vtekk00
Apr 26, 2005 06:38 PM
vtekk00
Apr 21, 2005 07:07 PM
