Intake Manifold for Forced Induction
Old Dec 25, 2008 | 12:19 PM
bcrichguitars's Avatar
Default Intake Manifold for Forced Induction
Has anyone heard anything about the Golden Eagle Turbo Intake Manifold? It costs $800 for a D series enigne, compared to half of that for other intake manifolds. Are the gains of an Edelbrock or Skunk2 Intake Manifold going to be as good on a turbocharged engine as they would on a NA engine? Can I really gain 10hp with an edelbrock manifold on a built/turbo'd engine?
Old Dec 25, 2008 | 12:53 PM
Also are Blox and OBX just as good as Skunk2 and Edelbrock?
Old Dec 25, 2008 | 01:20 PM
Blox... probably... the company was made by former employees of skunk2. look at both of their dual bend shifters and compare side by side, you'll see what i mean
OBX, no
i heard skunk2 isn't that great with sensor fitment and stuff so i wouldn't really put edelbrock and skunk2 on the same level
Old Dec 25, 2008 | 03:54 PM
inthezoneac's Avatar
search civic edelbrock intake dyno. Obviously with a turbo you'll get more power out of it, but on a stock N/A civic, I think it gained 8HP. Not worth the $300 or w/e it costs.
If you get/have a turbo, yeah I'd get it.
Old Dec 25, 2008 | 08:44 PM
Mr Mobsta Man's Avatar
If your going to get one, go with Edelbrock.
IMO of course...
Old Dec 26, 2008 | 08:34 AM
munkeewrench23's Avatar
just make sure you get the hondata mani gasket when you do the install they are pretty good in helping produce more power from your manifold. IMO i would look into a mani that has short runners which are better for turbo because the air shoots into the head of the motor faster producing more torque as opose to the long runner which produce more high end power.
Old Dec 26, 2008 | 10:53 AM
Thats good to know thanks alot guys I'm going to get the edelbrock with hondata gasket. By then my engine will be broken in and I can get it tuned with some boost!
Old Dec 26, 2008 | 04:05 PM
Marty's Avatar
They are not worth it? The edelbrock is worth it more so than any off the shelf intake. They have placement for a secondary fuelrail/direct fogger n2o system. Their runners are bigger. The throttle body plate can be machined past a 70mm bore. They are lighter. Them people have been making aftermarket intake manifolds sense before all your little ricer obx and skunk2 companies, they are way bigger than those companies, and they spend way more money on r & d than those other companies. Do you have any idea how hard it is to gain 8whp on a D series with a part that only takes 30 minutes to install?
Old Dec 26, 2008 | 08:25 PM
Hey Marty I have a question for you or anyone else who might be able to answer it. I've heard that the Performer X is the better manifold for forced induction but someone here mentioned shorter runners are better because the air is pushed into the head faster making more torque. The Edelbrock Victor X has much shorter runners and says maximum power between 7000 and 10 000rpm. I only plan on a ~8500rpm redline, would I be better off with the Performer X?
Old Dec 26, 2008 | 09:39 PM
you're probably going to want the performer X to help with mid-range power more
