Need Help: test pipe from header to 3inch catback
Old Dec 22, 2008 | 09:16 AM
thebadgator87's Avatar
Default Need Help: test pipe from header to 3inch catback
hey guys i was wondering if anybody knew of a test pipe to go from a megan racing header on a 99 ex to a 3inch catback exhaust the closest i have found is the megan racing 3inch universal pipe but like it says universal so i dont know if it will fit any advise is appreciated thanks for looking
Old Dec 22, 2008 | 07:37 PM
FlipHKD720's Avatar
is the catback custom? couldn't you just have them weld a flange onto the header?
Old Dec 23, 2008 | 10:14 AM
its a thermal exhaust
Old Dec 23, 2008 | 03:24 PM
the stock catalytic converter doesn't fit?
Old Dec 23, 2008 | 04:49 PM
Tiran's Avatar
Well we need to know the diameters of the two pipes you need to connect?
Also, why are you using a test pipe? Are you racing? if not I HIGHLY suggest you use a catalytic convert.
Old Dec 23, 2008 | 07:04 PM
FlipHKD720's Avatar
if theres a gap, i'd bolt the catback on and get a shop to just custom weld a flange/short piece of 3" piping
Old Dec 24, 2008 | 05:13 PM
why is that?
Old Dec 24, 2008 | 05:18 PM
Originally Posted by thebadgator87
why is that?
1. illegal
2. immoral, both because you're hurting the environment more than you need to and it's against the law
3. it makes your exhaust sound raspy
A test pipe only gains you 1hp or less over a high flow catalytic converter, making it not worth breaking the law. If you get caught, you're gonna be in deep **** too.
Old Dec 24, 2008 | 11:53 PM
croninc's Avatar
read this, it might change your mind. =)
http://www.importtuner.com/features/...val/index.html
Old Dec 25, 2008 | 02:31 AM
hows it any different then if i had a turbo setup
