o2 question
Old Apr 5, 2007 | 12:28 AM
rice99ex's Avatar
From: Utica, NY (home of The Saranac Brewing Co.) :)
Default o2 question
on my stock header the o2 sensor was located at the bottom just before the cat. With my new header if i am going to leave it there it would be grinding against the boot, would it be alright if I plug the hole, anduse wire extenders and put the o2 sensor in the top part of the header instead?
Old Apr 5, 2007 | 12:35 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: o2 question
You'll only get a reading from 1 out of the 4. It will read wrong.
Old Apr 5, 2007 | 08:39 AM
rice99ex's Avatar
would i at least be able to make the CEL turn off if i did this, and how much a of a difference would it make?
Old Apr 5, 2007 | 08:48 AM
June 2010 ROTM
Well, the CEL would go away because essential it would do getting a reading. The problem comes in if 1 is burning rich and the others aren't they computer things all of 'em are burning rich and will give more fuel accordingly. Shooting extra gas isn't the best for your engine. It could also be bad for you cat as well.
Basically, you can do it, but I highly recommend not doing that.
Old Apr 5, 2007 | 10:12 AM
mxs's Avatar
mxs
ORIGINAL: rice99ex
what boot?
what is your new header?
Old Apr 5, 2007 | 10:42 AM
wirphotos's Avatar
Man....I think you have the same problem I do! I bought a new header a couple weeks ago and after installing it, it rubs on the CV boot. I've been running without a 02 sensor there and it's throwing the CEL. I made some phone calls and they say the longer you run without the 02 sensor the sooner your cat will take a crap. For the guys who have aftermarket cats, they can run a simulator, but for anyone who has origal cat, I wouldn't run it.
By the way what brand header did you buy? Don't run that o2 or it will rip your boot right open.
This is what mine looked like
Old Apr 5, 2007 | 11:11 AM
That's freakin GENIOUS!^ Did you get a cheap model?
People wonder why it makes sense to spend a little more money for the name brand
Old Apr 5, 2007 | 11:24 AM
wirphotos's Avatar
This is a Megan Racing Header..... apparently the new batch is a bad batch.
Old Apr 5, 2007 | 11:50 AM
ORIGINAL: wirphotos
NO KIDDING?!? Wow, I would have expected much better from Megan
Old Apr 5, 2007 | 12:09 PM
rice99ex's Avatar
yes that is the same problem i am having, i have it plugged with a bolt right now tho.
so would it be a better idea to buy an extender and runthe o2up top, or keep it at the bottom and risk ripping that cv boot?
[IMG]local://upfiles/19422/1BBC1C0A7FC2405085D08D5CA3A12ADD.jpg[/IMG]
