O2 sensor question
Old Jul 20, 2006 | 11:55 AM
tools52's Avatar
Default O2 sensor question
i've got a d16y7 in my '00 dx & i'm gonna get a DC sports 4-2-1 header w/ high flow cat. on the y7 EM there are 2 o2 sensors, one before the cat, & one afetr. on my header & cat, there is an o2 sensor on the header, & one on the cat. do i have to put the stock o2 sensors in the same order or will it matter?
Old Jul 20, 2006 | 12:12 PM
Chimera02EX's Avatar
Default RE: O2 sensor question
Absolutely!
And you may wanna consider an O2 simulator for the "after cat" sensor. You will get a CEL from the header. The O2 sim will clear that up.
Old Jul 20, 2006 | 12:55 PM
tools52's Avatar
thanks
Old Jul 20, 2006 | 02:41 PM
tools52's Avatar
couldn't i just use the 2 stock sensors though?
Old Jul 20, 2006 | 08:07 PM
smit3413's Avatar
depends if the "high flow" cat is an actual cat. some high flow cats are just straight pipes. if it's a real cat, put the sensors in the same order. if it's a straight pipe, you'll need an O2 simulator for the second sensor. and you'll need to lengthen the second O2 sensor for the cat because i believe on the d16y7, the cat is on the header before the downpipe, and on the new headers and cats, the cat comes after the downpipe. that's what i experienced with my d16y7 99 lx...
Old Jul 20, 2006 | 08:10 PM
dfdon's Avatar
there order is for a reason they "sense" different things
Old Jul 21, 2006 | 07:33 AM
tools52's Avatar
i already have the cat and it definately is an actual cat, so what gauge wire would u recomend using to extend the sensors?
addiction2bass
Aug 14, 2008 09:53 PM
fglaustin
Mar 27, 2008 08:29 PM
vtec02
May 9, 2007 05:17 AM
00sithrottle
May 12, 2005 10:25 AM
