Sputter, Sputter
Old Apr 6, 2007 | 07:46 AM
Default RE: Sputter, Sputter
ORIGINAL: CityGrrl77
Check engine light has been on for a few years - even with the original motor. Had a tech guy at Toyota look at it (borthers friends' dad) when it first cam on and they said it could be a pinhole leak in one of the fuel lines (??) - something that would take forever to find and not something to worry about. Diagnostic test showed it was throwing the 'need a new gas cap' code and replaced that. Then replaced the Evap Canister on the old motor. The light still didnt come off. Whne I disconnect the battery to get e-checked, it ends up coming back onn 100 miles later. The sputtering just started with the swapped motor tho. Check engine light came back.
As far as I'm concerned, NO leak in the fuel system is small enough to "not worry about." However, it sounds to me like a timing issue. Do you know anyone with a timing light? Your brothers friends dads grandmas dog's brother's friend (the tech guy) has to have one. Bring your car in and have the timing checked, and adjusted if necessary.
Is your Distributor night and tight? If its managed to shake itself loose a bit, it might be moving and creating the "miss" that you're hearing.
Like the others mentioned, it's never a bad idea to change out your plugs and wires, maybe even slap a new dizzy cap and rotor in. These are things that can be done for fairly cheap, in an hour or less and will help ensure the longevity of your motor.
Good luck!
Old Apr 6, 2007 | 09:05 AM
Roadkillboy0's Avatar
yeah mine used to chug big time for a while but my check engine light wasnt on. but i got a tune up anyways and it now runs perfectly
David_S
Oct 24, 2013 10:06 AM
o320
Dec 1, 2008 08:18 PM
jacksmash
Feb 27, 2008 01:01 PM
blue89crx
Feb 13, 2008 01:18 PM
whtboy97
Nov 23, 2005 05:54 PM
