Throttle Body
Old Apr 12, 2006 | 07:23 PM
US3R!!!11one's Avatar
Default Throttle Body
Assuming a person has a CAI, an electronic fuel pump, and everything else stock on a car, what kind of negative side effects am I looking at with upgrading to a +15mm throttle body?
Old Apr 13, 2006 | 12:53 PM
Default RE: Throttle Body
Bump.
Old Apr 13, 2006 | 01:57 PM
psychocivic's Avatar
well if you're thinking of getting a new tb then i suggest to go with an intake manifold to match.
Old Apr 13, 2006 | 02:29 PM
fastman90's Avatar
The TB wont do a ton of good without other mods (like above mentioned IM), plus fitment could be a problem without a different IM.
Old Apr 13, 2006 | 02:50 PM
Already know all that. Just need the op answered.
[Edit] Thanks for the concern though. [/edit]
Old Apr 13, 2006 | 03:38 PM
Street Sniper's Avatar
+15mm? That sounds pretty big. This going on your motor? That woudl make it what? 75mm? I would think that if there were any negatives, you may lose some throttle reponse, but I havent' read that much about intake charge velocities.
Old Apr 13, 2006 | 09:57 PM
Believe it or not, I actually have one just laying around =P I just double checked, its 70mm not 75, so its only +10mm.
I Just wanted to double check, I've never really done much homework on throttle bodies. I also found out it wont hook up to the stock intake manifold, so I spent all day nosing around under the hood contemplating whether I should put the venom intake manifold back on or not. Thats when I noticed that hot air and bits of oil were shooting out of the oil cap when I took it off. Methinks thats not good. I'll probably be holding off any driving till I figure this out, hence my decline to go to the event this weekend =(
Probably a blocked pcv valve =(
StifflersMom
Oct 9, 2006 10:52 PM
pbrooks259
Oct 3, 2005 11:06 AM
fast93civic
Nov 27, 2004 01:02 PM
dmsteele92831
Nov 16, 2004 07:11 PM
SI_racer
Jul 26, 2004 04:32 PM
