use megan gakets or buy some oems?
just wondering if i should use the megan gaskets on my header or go buy some new honda ones cause when i had my toyota pickup i put a header on it (pacesetter, it sucked ended up cracking) i used the gaskets that came with the header and it leaked till i got some oem ones. Soooo which ones?
ORIGINAL: redridinhood
the header is brand new and has the new gaskets with it just wondering if they were any good or might leak
The megan gasket you get with the header may look like cheap rubbish but it seems to be doing a good job on mine so far, plus ive seen bolts work loose and fall off from re-using a honda gasket with a megan header.
