What the frick why is this happening?
Old Oct 6, 2006 | 11:17 PM
redridinhood's Avatar
Default What the frick why is this happening?
k just extended the wires for the O2 sensor so it could reach the hole on the downpipe of the header so everythin is plugged in and my check engine light is still freaking on why? I have the megan header on and just put on the drift spec exhaust but there is no cat right now (goin in tomorrow to get the magnaflow high flow cat welded in) so the exhaust is comin straight out of the header right now but should that matter for the sensors because they are before the cat...
Old Oct 6, 2006 | 11:23 PM
Sleepin95CivicDX's Avatar
Default RE: What the frick why is this happening?
try resetting the ecu, dont know if it will solve problem, but it couldnt hurt
Old Oct 6, 2006 | 11:28 PM
mybrokenblinker's Avatar
I did the exact same install on the exact same year. I disconnected and reconnected my battery and had no problems so you might want to try that.
ok how do i do that? and im gettin an ex ecu in a couple weeks when the supercharger goes on will that make a difference cause the car is an hx but the header and exhaust are for the ex
Old Oct 6, 2006 | 11:32 PM
Pete's Avatar
An EX ecu wont do anything for your car because its got "Ex" bolt ons.
Old Oct 7, 2006 | 12:13 AM
dude mybrokenblinker thanks so so much that worked everythin is normal thanks man that was killin me lol
Old Oct 7, 2006 | 12:16 PM
TunerShark's Avatar
sorry to go off topic but do you have any pics of the drift spec installed? id like to see what it looks like.
thanks
Old Oct 7, 2006 | 08:06 PM
StifflersMom's Avatar
Cat Fuсker
don't put an ex ecu on an hx unless you swap to an ex engine head.
Old Oct 8, 2006 | 09:06 AM
Good I'm glad it worked out for you
tuner student
Nov 22, 2007 09:36 AM
vbcamry
Jan 21, 2007 08:04 PM
dblclutchin
Jul 4, 2006 03:46 PM
viper200392630
Oct 10, 2005 09:56 PM
