Will it fit? SRI
Old Apr 12, 2006 | 04:14 PM
jonyg98civicex's Avatar
Default Will it fit? SRI
Hey guys, I have a 98 civic ex manual, and i just bought an AEM SRI from advancedautoparts and it says will fit most hondas from 96-00, so I was wondering if there is any diffrence between a dx,lx, ex with regards to installing an intake. Therefore I was wondering if the intake will fit, or do they make special ones for the EX model? And if anyone wants to share pics of it installed it would be great so i have some basis because i am a NOOB.
THANkS Bros
Old Apr 12, 2006 | 04:29 PM
slvcivic00's Avatar
Default RE: Will it fit? SRI
Most Honda intakes are about the same, however there are two different styles of intakes for single cam civics like yours. The EX model civic has a different intake manifold set up then the DX, and LX models do. Here are some pics:
EX (single cam vtec) intake: http://www.injen.com/webpages/intake.../rd/rd1520.jpg
DX, LX, (single cam non-vtec) intake: http://www.injen.com/webpages/intake...da/is1545p.JPG
Yours should have a straight inlet like the first picture, not a 90 angle bend like the DX, intakes.
Old Apr 12, 2006 | 04:55 PM
Yes it does, now I have 3 holes in the AEM SRI, but i only have 2 things to "plug" into it, do i just cover the extra hole with something, or is there supposed to be something else to "plug" into that hole, keeping in mind i have a 98 civic ex.
Old Apr 12, 2006 | 05:08 PM
slvcivic00's Avatar
Yes that 3rd hole is for 99-00 civics like mine that need it for an additional sensor or something. If you have a 96-98 (and you do) then just plug it up. My friend bought an injen intake for his 97 civic and the kit came with a plug to block the 3rd hole. Other than that just take out all the old stuff, and attach your new intake. There should be a DIY guide to intakes somewhere on this site, good luck.
Old Apr 12, 2006 | 05:10 PM
thanks alot bro you helped me out a lot
Old Apr 12, 2006 | 05:25 PM
slvcivic00's Avatar
Not a problem, thats what this forum if for, have fun with your new intake!
Old Apr 12, 2006 | 06:55 PM
Yo i have two more questions, I got the air temperature sensor to fit in nicely, but the other thing to plug in to the SRI seems like it should be in a little more than it is, is it supposed to be just kind of in there, like it seems it should be in a little farther or im just being to ****?
And also, after i install it all the way, do I than, reconnect my battery wire, than start my car and let it run for 10 minutes, than turn my car off, than turn it on again to reset the air temperature sensor, does that seem right?
Old Apr 12, 2006 | 08:08 PM
slvcivic00's Avatar
This other thing is just a vacuum line that runs to your cylinder head, and yes it just kind of sits in the intake and draws air from it. Also, I never disconnected my battery when I installed my intake, but if it sets off your check engine light (for some odd reason) then disconnect your battery wait for like 30 sec. then connect it back up and everything should be good. Oh and also I got the perfect picture for you, it is an AEM SRI on a 97 EX civic. This is how it should look, plus look at the other pics on this page for help, hope you are good to go now.
http://memimage.cardomain.net/member...80_25_full.jpg
Old Apr 12, 2006 | 08:43 PM
yup thats exactly what it looks like, i went out on a test drive, and it sounds normal until it hits VTEC and it sounds SWEEEEEEEEEET, no major upage on the HP scale but definately sounds sweet when i punch it, THANKS FOR ALL YOUR HELP YOU RULE!!
Old Apr 12, 2006 | 09:22 PM
slvcivic00's Avatar
Sweet, I am glad it finally works, I don't know tons about cars, but intake/exhaust and suspension are my specialties because I have done them already to my car. Plus I had nothing else to do today, lol.
snaowke
Oct 20, 2008 03:47 AM
ladyM08
Apr 14, 2008 01:08 PM
ladyM08
Apr 14, 2008 12:46 PM
shikoz
Apr 11, 2007 04:51 PM
Stumasters
Jan 8, 2007 11:51 PM
