94 to 96
Old Jan 24, 2006 | 12:26 AM
lorenzoOKC's Avatar
Default 94 to 96
ok i'm new to the honda world this Fri. i'm about to get a 94 2dr civic, but what I wanted to know is that I like the headlights from the 96 how hard would it be to convert it or would it be a direct swap as in buying fenders,hood, and bumper
Old Jan 24, 2006 | 01:14 AM
idontknowmuch's Avatar
Default RE: 94 to 96
well the I have a 94 sedan and the first thing you do to convert to a 96 front bumper , headlight and hood is to unscrew all the screw and nuts and bolts in the front portion of your car.
then you label the screw, nuts and bolts on where you got it from or uncrewed from. then you slowly take all the exterior thingys out and you put the 96 exterior you might want to wear gloves on doing this project.
Ahh give yourself a pat in the back because you just convert your 94 to a 96
ps dont forget the screw nuts and bolts
I hope this help i dont know much but this is close enough, Im not a mechanic but I slept in holiday inn
Old Jan 24, 2006 | 04:23 PM
lorenzoOKC's Avatar
so is it a perfect match or is there any custom involved
Old Jan 24, 2006 | 05:33 PM
CivCoupe97's Avatar
Don't hold me to it but what I have heard it that the fenders are longer than what they are on the 93-95 models. I think the 96 fenders have to have a section cut out and then welded back together to shorten them. But i'm not positive about that. If I were goin' to spend the time to change it to a 96-98 front end I would just go ahead and do the 99-00 swap. It looks much better imo.
Old Jan 24, 2006 | 07:12 PM
BallardCivic's Avatar
Getting a 96 and up fender to fit on anything older is a pain. Is the deal on the 94 final? If not, you might want to look into a 96 or up.
Old Jan 24, 2006 | 10:20 PM
lorenzoOKC's Avatar
i'm gettin the 94 for $750 can't let that past by, the reason i'm getting it so cheap is that dude is leaving to army. See i'm new to the honda world or soon to be I also own a 93 madza mx6 so I come from the mx6 forum and just wanted some info on converting the headlights thanks!
Old Jan 24, 2006 | 10:28 PM
mxs's Avatar
mxs
you need to talk to this guy! check out his 5th gen -> 6th gen conversion.
https://www.hondacivicforum.com/fb.asp?m=156227&key=
