96-98 Headlight Question.
Old Feb 24, 2006 | 02:31 PM
VTECRunner's Avatar
Default 96-98 Headlight Question.
Is there anyway to get rid of those YELLOw/ORANGE stripe/spot? A lot of people are syaing oyu can but no one has ever said how. Is there any actual way to remove it?
Old Feb 24, 2006 | 02:42 PM
amg6975's Avatar
Default RE: 96-98 Headlight Question.
I think you can take the housing apart and pop it out. That involves heating and all sorts of stuff. I don't know the exact process but I'm sure you can find it if you look around here and/or google.
I think jut buying a set of clear headlights would be the best way to go, check eBay.
You could also do a 99-00 front end swap but that gets pricey. And no, the 99-00 headlights aren't a direct swap.
Old Feb 24, 2006 | 03:56 PM
baker's Avatar
take your headlight out. get a blowdryer heat up the sealant, pry it apart with a butter knife, take out the yellow stripe thingy. get some clear window caulk, put your headlight back together.
Old Feb 24, 2006 | 04:04 PM
Remmy's Avatar
Yea, dont stick it in the oven like some people say.
Old Feb 24, 2006 | 04:33 PM
baker's Avatar
you can put it in the oven... i wouldn't... but you can.
Old Feb 25, 2006 | 06:55 PM
Solid_Snake's Avatar
when i painted my headlights I did the blowdryer process, that is, to use the blow dryer to soften the sealant and carefully popping the lense
sorry for the threadjack
si4ever
Apr 23, 2007 04:26 PM
ProjectGSR
Feb 7, 2007 11:49 AM
joel929
Sep 7, 2006 05:05 PM
D16z6
Sep 2, 2005 04:37 PM
D16z6
Jul 23, 2004 12:35 AM
