Carbon fiber hood
Old Mar 23, 2009 | 05:40 PM
lowlife9's Avatar
Banned
my vis evo hood has a removable water trap in the large vent but evan if it does rain on it it wont really effect the filter much there no way to get water lock that way the filter would have to be submerged completely .and if your that worried about it injen makes a water proof cover for any size filter that does not effect the air flow these were designed for cai to prevent waterlock. there like 20 bucks
Old Mar 24, 2009 | 01:26 PM
enigma34's Avatar
I could make something to cover the vents when raining? Tape the vent from the inside?
Old Mar 25, 2009 | 11:09 AM
lthao61's Avatar
anything attached to your factory hood use it on the VIS one.
four bolts and a few water hoses are also attached, not to mention the water squirt nozzles
Old Mar 25, 2009 | 03:03 PM
lowlife9's Avatar
Banned
you could seal it permanently or wait did you just say duct tape dam well the mesh thats in the vis is removable they just use bendable metal so i guess you could put whatever you could imagine in its place also invest in a dremal for the pins and the washer fluid holes need to be expanded to fit properly .
Old Mar 25, 2009 | 06:32 PM
enigma34's Avatar
If the hood i get does not have holes for the washer fluid, I'm not even going to bother.
Old Mar 25, 2009 | 07:14 PM
lowlife9's Avatar
Banned
no it has holes but there just a little smaller then stock.
Old Mar 26, 2009 | 05:15 PM
PA412's Avatar
i'm pretty sure you need squirters to pass inspections in some states.
Old Mar 27, 2009 | 10:08 AM
lol that hood'll have you driftin around corners like a mad amn i can see your black red and blue ccaar just slidin around a right turn now hehe
Old Mar 27, 2009 | 10:28 AM
enigma34's Avatar
The only inspection we have in ct is emissions. And i look at all the test they do, and none are for safety. My horn is disabled because i didn't hook it up with the new steering wheel, and i know that some states test horns, but nowhere dos it say they test this stuff.
Old Mar 27, 2009 | 10:32 AM
enigma34's Avatar
The hood will make the car look better. i guess carbon fiber is the fourth color? The center caps for my rims are carbon fiber.
