cut wire brush!!!
Old Jan 15, 2008 | 11:39 AM
95civiclsi3door's Avatar
Default cut wire brush!!!
hi everybody, i was watching a video about PAINTING ALLOY. and he used cut wire brush on a drill machine to sand the alloy, just worndering is it ok to use for plastic or steel alloy rims???
Old Jan 15, 2008 | 12:28 PM
Default RE: cut wire brush!!!
any comments????? any idea??? will it damage the rim???
Old Jan 15, 2008 | 05:42 PM
TheInternet's Avatar
Most important thing to keep in mind when painting is preperation...without a well prepared and clean surface area the end result wont look nice...
So I assume the wire brush was used to 100%remove all rust and flaking clear coat...a wire brush on a power drill might be a bit much since it can leave deep scratches in the wheel depending on the pressure and type of brush, I didnt see the video, but be careful about that...or you can use files and sandpaper, or a grinder type thing with sandpaper on a rubber pad attached...depending on the tools you have and how much you want to invest...
Or if they are really expensive alloys you can bring them to a professional paint or body shop to paint or powder coat them for you...if you prep the alloys yourself, you can save some money...or they can sandblast them for you, or whatever...Id call around and get some quotes...
http://www.autospeed.com/cms/A_2303/article.html
Look on google there are 100s of articles about this...
And no, dont use wire brushes on a drill for plastic hubcaps it will just melt the plastic...just use sandpaper and clean it wellby hand...
Old Jan 16, 2008 | 03:21 AM
thanks, thats what exactly i need to know before i start. No they r not that expensive, so i try to do my self see if i can fix them. files r a good idea. i tred to see, and they comeout brilliant
Old Jan 17, 2008 | 07:04 PM
ORIGINAL: 95civiclsi3door
Hi man, heres another DIY I just came across, it looks good, and pretty simple to do...
http://www.torontocivics.com/tccv5fo...hread.php?t=68
xsdudztx
Aug 14, 2007 05:45 PM
xsdudztx
Aug 9, 2007 07:45 PM
joshydee
Nov 30, 2006 05:19 PM
herbaleyes
Nov 26, 2006 12:33 AM
deadcivic
Jan 23, 2005 03:11 PM
