Decal help
Old Aug 30, 2007 | 08:27 AM
BillyB98's Avatar
Default Decal help
I recently purchased an 18" x "113 decal from decalkits.com and installed it myself. This process did turn out to be a lot harder than i thougt due to the side moldings on Civics butit actually turned out very good and the decal molded right into the side moldings on the car. Now about a week after the istall it is still looking good except for the areas that had to be pushed in around the side moldings. It is pulling up and getting ridiculously bubbly. What can i do to fix this? Any help is greatly appreciated!
Old Aug 30, 2007 | 08:37 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: Decal help
The best thing to do it to get a razor and CAREFULLY cut where the molding meets the body. Then with your finger or a rubber smoothing tool, smooth the bumps. No one with notice the small lines.
Old Aug 30, 2007 | 09:59 AM
BillyB98's Avatar
Yea thats what i was thinking i would need to do. Thanx for all the help. What if it doesn't restick though?
Old Aug 30, 2007 | 11:09 AM
June 2010 ROTM
Then well, you're F'ed!!! jk
If you're working with vinyl, which it sounds like you are, it should still stick otherwise I would suggest finding some sort of adhesive that won't wreck the paint. And the only thing I can think of is 3M double sided tape.
Old Aug 30, 2007 | 12:07 PM
BillyB98's Avatar
alright thanks a ton Dano
Old Sep 1, 2007 | 07:55 AM
JKinATL's Avatar
I bought my first Civic last week! I don't know how I did without.
I need some help, please:
I want to move the stock 'Civic' badge on my '07 that's on the rear left to the center rear, either right under the "H" or lower, right under the license plate.
1. How do I remove the badge cleanly, preserving the badge and leaving a clean surface where it was?
2. How do I reattach it? Recommendations for adhesive, etc?
Are there kits out there that I can buy to do this? My tools are limited.
Thanks!
Old Sep 1, 2007 | 11:33 AM
BillyB98's Avatar
Make a new thread with these questions cuz we were talking about a totally different subject
Old Sep 1, 2007 | 03:17 PM
JKinATL's Avatar
ORIGINAL: BillyB98
Actually, no it's not. It's saving space, too.
Old Sep 1, 2007 | 07:36 PM
99lx's Avatar
Actually, yes it is. Notice how the original poster is asking about installing a decal, and here you are asking about moving your badges around.See how they are two totally different subjects?!?
Old Sep 1, 2007 | 09:33 PM
FlipHKD720's Avatar
put a pin-hole in the middle of the bubble and push the air out through that hole. It works well and you cant see it that bad but i wanna see pics anyway!
