Depo Foglights
well if the plastic trim doesnt fit right or STAY tight to the body.... glue them to the bumper cover tight with some plastic epoxy..... just be sure to hold the trim panel TIGHT until its dry and hard so it will stay inplace! just be sure you have your fog lights adjusted right before ya glue that bezel down
my one side doesnt quite sit flush as the other side and mine are OEM fogs BUT my bumper cover is aftermarket so thats where i suspect the real problem is!
ORIGINAL: addiction2bass
ORIGINAL: Ej1Rider
hey prekgsr, take a pic of your foglights on the part that you cannot stand, so i can see if it s fixable
well see whats actualy the problem....... if the bezel wont touch the bumper... then id take the bumper off and try sanding down the plastic mounting tabs ON THE BUMPER COVER from the back side... that will let the ACTUAL fog light housing sit closer to the bezel! and if ya have to pull the bezel off and sand down its mounting tab alittle to cause it will probably hold that side further out... but just take some time looking at it and see if ya have to sand alittle mounting tab down or put a washer on it to hold it further apart...
looks like ya cut alittle to much around that mounting screw..... that was the hardest spot for me to get right...
just think about it before ya cut anymore out... you cannt add plastic as easy
depo are good foglights brands, i tried ebay brand because htey were selling for 60 dollar u know what they say u get what u paid for, the foglights started to leak and mold inside
i have depo now andi havent run into anyproblems with it. . i got 99 foglights my friend got 98 fog lights both fit great but on the 98 fog lights u will find a slight fitment issue where the fogs dont sit right but that's because of how the 98 fogs are not the foglights itself
well for youu foglights they look like they fit pretty okay, foglights are made to be looked at from the front and not the top down, i guess u can try triming some more plastic to make it fit nicer other then that it can just be the foglight cover itself
ooo try adding something inside the foglight to make it more center, try adding like a block of stick and zip tie it so the fog lights centers more =)
