Fog Light Bulbs?
Old Dec 16, 2009 | 09:44 PM
  #21
dude, i just told you. Have you even tried looking for yourself?
Old Dec 16, 2009 | 09:55 PM
  #22
KingDakota12's Avatar
No I know you told me its on the lens ill check tomorrow I was just wondering if the high and low beam bulb size are both on the lens.
Old Dec 16, 2009 | 10:12 PM
  #23
I don't know if they are or not. There's no way for us to know that. Not every headlight is the same...
Old Dec 16, 2009 | 11:09 PM
  #24
take out the bulbs and take a look, its on the bulb as well
Old Jan 5, 2010 | 09:19 PM
  #25
These are white, with a slight hint of blue
http://cgi.ebay.com/ebaymotors/NOKYA...Q5fAccessories
Just purchased these tonight. Will I need a heavy duty wire harness or will it work I don't understand what it does or if I need it?
Old Jan 5, 2010 | 09:25 PM
  #26
The heavy duty wire harness has thicker wire than OEM in order to better withstand the higher draw of the new bulbs. However, while it is true that thicker wire is needed to handle more power draw, I am not convinced that this increase in power draw requires thicker wires. I, along with a few people I know of, have been using these bulbs just fine with the OEM wiring. I think that the suggestion made by the retailer for you to use the aftermarket wiring harness lies in the fact that they just want to sell you more stuff.
Old Jan 5, 2010 | 09:33 PM
  #27
Ok awesome thank you. Pretty excited speaking that my OEM bulbs were so crappy and had no lighting to them at all. Just need to get silicone and re seal the fogs and put the bulbs in. Woo!
Old Jan 6, 2010 | 05:58 PM
  #28
i have no problem using higher wattage bulbs with oem wirings but i have read that some people did. not a lot though
Old Jan 16, 2010 | 03:41 PM
  #29
Ok well I bought those 5,000K Fog light bulbs TrustDestruction showed me and used the stock wire harness and it worked that night and the following night, but both went out now and have no reason why? Just need to get new bulbs and a heavy duty wire harness?
Old Jan 16, 2010 | 04:36 PM
  #30
Scott53092's Avatar
There's a good chance that the wires could have shorted out. Check the fuse.
