glow on stock gauges
i have an 03 ex and im wondering if i could change the color of the glow on the gauges. its currently like a purplish blue? something like that. id like to change the color though. anyone know any websites for it or any information on it
Addiciton and I used led strips found at Oznium.com to glow the stock gauges. Heres addictions writeup as well as my resulting pictures.
Write-Up (DIY)
https://www.hondacivicforum.com/m_313584/tm.htm
My Results
https://www.hondacivicforum.com/m_343651/tm.htm
Basically it's pretty simple to do. Basic soldering and knowledge of removing and taking uapart your dash and clusters. Time and patience is the key. Good luck!
Write-Up (DIY)
My Results
ORIGINAL: TBon3
Do you have to buy a used cluster to do what addiction and gin0o0o did? Or can you use your existing one?
you can wire the LEDs to their own switch so you can turn them on and off whe nver you want. Or you can wire them into the board so they can dim. Ask addiction or ginooo about that. You can use your stock gauges, just take a few screws out around the bezel and you'll be able to pull the entire cluster out. From there, open it up and follow the DIY.
www.speedhut.com has some sweet gauges for a decent price though, check them out.
