guages + pillar pod
I am thinking about getting a triple guage pillar pod, i saw the DIY intructions but i think im getting air/fuel ratio, oil press, and voltage. Is it hard to hook up these guages? Like where do you have to run the wires to? Do you need to do any modifications or is it pretty simple? also, do you think the guages with a white face are better or the ones that glow?
Pretty sure the oil pressure gauge just taps into the Oil sending unit. It is a sensor that is located directly above your oil filter. You cant see it unless u take off the oil filter.
I'll be hooking up a dual gauge pod within the next few weeks and I hope to write a how-to. It does help to have a service manual, especially a factory manual. I bought a used one for $44 (on the internet), but you can find Haynes manuals for $15. They include wiring schematics that are not too hard to figure out. I'm not sure where you can connect the air/fuel ratio wires - possibly the exhaust manifold?
Oil pressure is good to have but the readout I use the most (in my Corvette) is oil temperature. At 160F, I am free to get the revs up as high as I want. Unfortunately, I haven't seen this type of gauge in my Summit catalog. Otherwise, I'd stick one in the Honda.
An air fuel ratio gauge just gets spliced into the o2 sensor......the one youve got isnt accurate thou, so I sure hope its just for a light show.........cuz you cant tune anything with it.
By the way, have any of you guys removed your pillar cover? My service manual should arrive in a few days, but it may not mention this. I guess I can always ask the Honda parts guy at the dealership, but if someone here has already done it, maybe you can let us know how that thing comes off.
ive got all 3 in my civic
A/F as pete said just splices into the white wire of you o2 sensor
volt- just a simple ground and power
oil press- sending unit to the right of your oil filter
just but a bunch of wire all very doable
ORIGINAL: conceptualpolymer
