Halo Lights
Old Jun 29, 2005 | 10:06 PM
terraeisa's Avatar
Default Halo Lights
I purchased some Halo lights from Ebay for my 90 Civic HB and want to know will they be difficult to install and will I need a specific bulb? If so, what do I do?
thank you
Old Jun 29, 2005 | 11:42 PM
Mad7s's Avatar
Default RE: Halo Lights
Not difficult. Remove the bumper, remove the headlights, put your new ones on. No new bulb is necessary.
This site willl help with the bumper removal under the "How to's." Good call on the Halos by the way. Get some pics up when you're done. Good luck with it all. Not hard. Easy.
Old Jul 1, 2005 | 07:17 AM
terraeisa's Avatar
Thank you Mad7s, but what about the bulbs. What do I use for headlight bulb and what bulb do I use to make the halo effect. I have look at some model numbers, but it just confusing. I've seen #9005, H1, H2 ,#9004, etc.
thanks honda crew,
Old Jul 1, 2005 | 09:29 AM
Mossy's Avatar
the halos i bought already came with the bulbs, all i had to do was plug it in. the actual halo's though are led's and you have to wire them to a 12V source
Old Jul 1, 2005 | 01:27 PM
mill$civic's Avatar
ya what they sead..the halos should just be a led that get wired into a 12v power supply and the lights themselfs will probley come with lights in them,they just got to be pluged in were your old lights were..plug and play..bye the way..the way that i did it was u should hook your halos up to a switch inside your car this way u have controle when u want to put them on or not..check them out..https://www.hondacivicforum.com/albu...ge=&sortType=6
Old Jul 5, 2005 | 06:08 PM
KnightRiderCivic's Avatar
yeah i have a set of them on my 00 civic with the black background and projector headlights. the only thing is the pic i seen on ebay and ordered had two halos and when i got mine it only had one around the inside light. still looks very sweet at night with just the park lights on and the halos.
Old Jul 9, 2005 | 11:10 PM
terraeisa's Avatar
thanks everyone, but I found out that I bought projector lights and not halo. What is the difference? Which is better for night vision? What bulbs go into the projector lights.
thank you
Old Jul 10, 2005 | 12:46 AM
Mad7s's Avatar
No way, that's insane. Terraeisa, mind if I ask where you got yours. My 88 might be calling for some. If it's off Ebay, know know the seller? Thanks.
Old Jul 10, 2005 | 01:23 AM
I met two guys tonight with different civics, that both had recently bought halos and had problems. The one guy's driver side far right light didnt work. And the other guys passenger center (the big one) was out. I know the second guy has only had his for like a month. Has anyone else experienced anything like this?
Old Jul 11, 2005 | 11:08 PM
terraeisa's Avatar
I got mine off of ebay. Also, what bulbs do I use crew? I have a rubber cover that pops off the light, but there are 2 wires with connectors on them. One is blue, the other is black. What bulbs do I need for proector ligts? I am new to this so please explain.
itzcorky
Sep 21, 2011 07:45 AM
pimpossible
Oct 27, 2007 10:23 AM
KraziAzn
Aug 27, 2007 05:56 AM
silvercivic97
Mar 16, 2005 09:36 PM
