halo vs. stock question
Old Jul 30, 2007 | 05:47 PM
Rklamb16's Avatar
Default halo vs. stock question
I am going to buy some black housing halos, but I notices that there are 3 holes for bulbs on the halos, and only two for the stock headlighs (turn, hi/low) what would go in the thirs hole on the projectors?
Old Jul 30, 2007 | 05:55 PM
FlipHKD720's Avatar
Default RE: halo vs. stock question
from hte outside in, blinker, low beams, high beams. The OEM headlights just use one bulb for highs and lows, the projectors you are talking about, it just switches between the two bulbs instead
Old Jul 30, 2007 | 06:02 PM
Rklamb16's Avatar
so if i got sylvania silverstarts, which one would that go with, hi or lo? because on the package it says both. And how would i hook up them separatly if the harness only holds two bulbs?
Old Jul 30, 2007 | 07:53 PM
danomatic93's Avatar
June 2010 ROTM
most projector headlights come with a harness that spearates the wires for hi and low beams to two different bulbs. The bulbs for low and hi, with the new projector headlights are usually both H1 bulbs, which completely replace your old single bulb.
So, wait to get bulbs until you get the projector headlights. They will tell you which bulbs you need then.
Old Jul 31, 2007 | 02:03 AM
Rklamb16's Avatar
do the sylvanias typically replace the hi or lo beam?
Old Jul 31, 2007 | 05:30 AM
Stumasters's Avatar
They will replace both..
Hi beam = H1 55w (small bulb)
Low Beam = H1 55w (small bulb)
There really isn't much difference in the bulb type, hi or low, it's just they way they are focused.
Your projectors will have a cut-off, your bright's wont, they just glare everywhere.
You will need 2 sets of 2, or 4 individual H1 bulbs to convert the yellow standard bulbs to silverstars, assuming that the kit you are getting comes with bulbs, and is H1. Most standard halo systems are H1 bulbs.
If you are budget minded, buy a set of 2 silverstars, put them in your dim's (projectors), and then later grab a 2nd set and put them in your brights. The harness knows when to change from low to high, depending on when you flip your switch. It's confusing going from 1 to 2 bulbs, but you won't have to do anything extra in the form of wiring to make it work. It's all plug-and-play.
Old Jul 31, 2007 | 05:33 AM
Rklamb16's Avatar
thanks alot!
pimpossible
Oct 27, 2007 10:23 AM
KraziAzn
Aug 27, 2007 05:56 AM
windcalmer
Jan 18, 2007 12:07 AM
dblclutchin
Nov 28, 2006 07:25 PM
RedlineRacerCMD
Mar 8, 2006 01:47 PM
