Has anyone painted headlights?
I heard you can pry the clear plastic off the front and paint the background behind the bulb. Has anyone ever heard of this?Thanks
RE: Has anyone painted headlights?
Use the search! Just type in "paint headlight" and you should find what you need.
I have on my aftermarket lights. Check the photo album. What questions do yo have?
There are two metal clips on top and two on the bottom that hold the lense (clear part) to the bezel (inside part) ALONG WITH a very tough adhesive. Keep the clips because when you go to re-seal the headlights, they help hold the lense on until the new adhesive hardens.
Step 1: remove headlight from car. Step 2: remove bulbs from headlights Step 3: remove metal clips Step 4: remove adhesive To get the adhesive off, either bake the headlights (I don't know how to do this and haven't done it, so search for it) or get a box cutter and cut the adhesive off. DON'T CUT YOURSELF!!!. Once the lense is independent of the bezel... Step 5: prep the bezel Get some sand paper and sand the bezel (the parts that you can see through the lense normally). I suggest starting at say 600-800 grit and work your way up to 1000+ grit. Be gentle, otherwise you'll leave grooves. Remove dust from sanding Step 6: Get some paint and paint them. I suggest spray paint. I used Rustoleum Gloss Black. You can use a primer and/or a clear coat, but I figured once it's re-sealed the paint won't get much air flow. Also if you haven't used spray paint before, ask me for spray tips. Step 7: Re-seal the headlight assembly I used ATV sealant, which is found in the automotive section of most stores, that or at an auto store where the whole store is the auto dept. Step 8: Install Headlight and bulbs. DON'T FORGET TO PROPERLY AIM THE LIGHT BEAMS!! (or don't but they'll be all cock-eyed) Step 9: Smile and change your shorts. |
addiction is your guy to go to for this
Ok just so Im reading the search correct.... i put my headlights in the oven for 5 minutes at 200 degrees?? Then they should come apart easily? thanks
Wow ok I tryed it anyway and it came off in literaly 3 mins...... Thanks
So wheres the pics?
I dont have my digital camera anymore. It broke Ill have to borrow my friends.
hey i think what your asking about making your stock EK headlights assemblys look like the type R ones right? all i kno is you put the head lights in an oven so the seals come apart and you paint it and then seal them back up. these look sick check my profile on here i have them on my car and they look amazing. i bought mine from a friend but you can paint the amber reflectors too for that one-off custom look.mine have that burnt orange color to them and another thing you can do is the little shroud that covers the bulb you can take that off and the lights are bright as ****
