honda cancer fix, need help with paint
so i did my best to fix the rear quarter panel on my civic:
[IMG]
[/IMG]
heres what it currently looks like:
[IMG]
[/IMG]
what should i do about the paint? would it be possible to blend the new paint in so it isn't very noticeable? should i just get the matching paint in a rattle can?
[IMG]
[/IMG]heres what it currently looks like:
[IMG]
[/IMG]what should i do about the paint? would it be possible to blend the new paint in so it isn't very noticeable? should i just get the matching paint in a rattle can?
oh and if anyone wants to know how i did this i'll give a quick runthrough.
i used an angle grinder to get rid of all loose paint and most of the rust:
[IMG]
[/IMG]
[IMG]
[/IMG]
then i used a bendable peice of aluminum to reshape the wheel arch. i then cut out a peice of sheet metal and welded it into place using a mig arc welder (the mig was too hot, i would use a tig if you can have access to one). you could also rivet the metal into place if you dont have a welder.
then i started with the bondo. [IMG]
[/IMG]
i put on about 6 layers so i could get the right shape. i used the other quarter panel as a "guide" which was helpful.i sanded after each layer of bondo and then used spot putty to fill in any little holes. now im about ready to paint, although i'm probably going to do the rust by the door this week and then paint it all together.
[IMG]
[/IMG][IMG]
[/IMG]then i used a bendable peice of aluminum to reshape the wheel arch. i then cut out a peice of sheet metal and welded it into place using a mig arc welder (the mig was too hot, i would use a tig if you can have access to one). you could also rivet the metal into place if you dont have a welder.
[/IMG]i put on about 6 layers so i could get the right shape. i used the other quarter panel as a "guide" which was helpful.i sanded after each layer of bondo and then used spot putty to fill in any little holes. now im about ready to paint, although i'm probably going to do the rust by the door this week and then paint it all together.
You're also going to have a hard time with the door. My guess is that it's rusted in the crimping of the door as well (where the metal folds over on the edge) and it's impossible to sand that out. You could try this stuff that turns iron oxide into iron phosphide--a usable metal but I tried that on my hood where rust was in the crimping and it didn't work. When done you can try to rattlecan it, but I've found if you're doing a large area it doesn't last real great. I plan to buy a cheap paintgun this summer and try that to see if that works any better.
[/IMG]
[/IMG]
[/IMG]
