How do you install a spoiler/fender???
Old May 26, 2005 | 08:09 PM
D16z6's Avatar
Default How do you install a spoiler/fender???
I have 94 coupe oem spoiler and was wondering whats the proper way to install it?? without leaking when it rain and what tools will i need??
Also how do you remove the front right fender??? will you have to remove the front bumper and the underside molding?? How hard is it???
Old May 27, 2005 | 10:07 AM
D16z6's Avatar
Default RE: How do you install a spoiler/fender???
anyone??
Old May 27, 2005 | 03:36 PM
hondabboy's Avatar
lol
well the proper way to install a spoiler is by using rulers and crap to properly align the wing and use a drill and the drill bit has to be the exact size as the screws you'll be using to install the spoiler make sure you use washable marker to correct for mistake and when fine with what you have then install the spoiler.
4 the fender yes you must take the front off to get easy access also you have to have the door open. and the underslide molding. good luck
Old May 27, 2005 | 07:17 PM
ngoti 8tor's Avatar
Also, when you install the spoiler, you should put rubber gaskets between the spoiler and the trunk lid. These should come with the spoiler, if not, you can just cut em outa thin rubber material.
Old May 28, 2005 | 01:05 AM
D16z6's Avatar
how do you wire up the 3rd brake light on the spoiler?? should i also remove the 3rd brake light inside behind the rear window since i already got one on the spoiler??
B_Ray
Feb 24, 2021 11:23 AM
DannyHC
Jun 19, 2009 05:45 AM
Vexorg
Apr 9, 2006 10:19 AM
zdzichoo1
Dec 31, 2005 12:29 AM
njhatch03
Dec 13, 2005 05:25 AM
