Painting Side Mirrors
good paint foremost. plus a good sprayer.
also use good primer underneath and a good clearcoat on top. and do it with with calm wind conditions (preferrably inside a closed space).
body shops charge hundreds of dollars to paint small pieces on a car partly because the paint is so expensive.
you may want to try krylon, however, that has a new plastic-bonding paint. it's cheap and if it works, you saved a ton of cash.
lots of wet sanding, lots of prime, lots of paint, LOTS of clear coat. Make each coat really really light and even and take your time, especially if your doing it with a spray paint can. Its possible to do it with the can and wihtout a gun, but you just need to take your tim and get the right shade of paint. Usualy auto shops cna take a look at your VIN number and custom mix you a can of your own paint for not that much money.
Yeah thanks a lot guys, I'm a DIY er and I cant wait till the warmer weather hits. The mirrors should not be too difficult and they are easy to remove and re install. I would take pride doing it myself and it won't cost too much. I was also thinking about painting the license plate piece on the trunk.
i got my bumpe repainted too, after the clear coat application, do i still need to buff it to come up with a glossy outcome? i've noticed that the surface is not that smooth and it is not glossy.. can anyone give me a step by step guide on painting... tnx
ORIGINAL: cathy20
