projection head lights
Old Nov 5, 2007 | 01:28 PM
ltkenbo's Avatar
Default projection head lights
Why do a lot of these projection lights have 2 differents spots for bulbs (1 for the low and 1 for the high) when my civic '99, has a dual filament bulb for lows and highs?
http://cgi.ebay.com/ebaymotors/99-00...spagenameZWDVW
Old Nov 5, 2007 | 01:31 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: projection head lights
The open one (you can see the bulb) is the high beam and the projector bulb is the low beam.
Old Nov 5, 2007 | 01:33 PM
dito.........
Old Nov 5, 2007 | 01:42 PM
ltkenbo's Avatar
ORIGINAL:ltkenbo
Yes I know, but my question is,why are they that way when my car uses a dual filament bulb, one for the high and one for the low. Wouldn't getting these require some splicing?
Old Nov 5, 2007 | 01:45 PM
well no splicing needed.....
some wiring alittle depending on the wiring that comes with it.... the projectors i bought for my 94 has a total PLUG IN PLAY.... plugs right into the stock wire harness....
and for my 99s HID bulbs i did i had to use some SPADE terminals slide into the stock harness for them to work. BUT no cutting needed.... very simple....
Old Nov 5, 2007 | 01:51 PM
ltkenbo's Avatar
For the HID bulbs did you buy 2 sets than? 1 for the high and 1 for the low, because I know some kinds (like the ones onzium sells) have a a regular halogen one built into the HID bulb and one set uses and electromagnet to move it.
The reason I was asking is my dad is going to give me a set in a couple of months.
Old Nov 5, 2007 | 02:22 PM
well either way ya go you have to buy the BULBS for the headlight housings!!! most projectors are H1 i believe..... stock headlight housings are H4... i have H4 cheap HIDs just low beam HID and high beam cheap bulb dual fillement...
tho with these HID low, and regular high beams.LOL the high beams are a joke!
what i did with my 99 is add OEM foglights to lite up the area beter...
Old Nov 5, 2007 | 05:44 PM
June 2010 ROTM
ditto, the HIDs are sooo much brighter than the regular lows AND highs.
Both my "high" beams are actually burned out anyway, apparently. As a demonstration to a friend the other night I switched to my high beams and I only have the parking lights. That was scary. I checked the bulbs to sees that both were out. I'm not going to replace them either because, well, I never use 'em!!
Old Nov 5, 2007 | 06:00 PM
basbal123's Avatar
^^ yaa that happend to me too is there away to get the highs to works too
Old Nov 5, 2007 | 06:01 PM
June 2010 ROTM
Do you mean at the same time? Or as HIDs?
