Question About Gauge Cluster/Speedometer
Old Apr 19, 2012 | 09:16 PM
warchief337's Avatar
Default Question About Gauge Cluster/Speedometer
I have a 1996 Honda Civic DX coupe Manual and want to get a speedometer with a tacho on it , anyone know any good tutorials on how to install and does anyone know of any good sellers for this?
Old Apr 19, 2012 | 11:48 PM
xbesox's Avatar
eBay has a lot of sellers check it out. As for how to install it it's pretty easy!
First locate the two screws on top of your cluster (from inside) and remove them.
Second hold the black plastic frame from the bottom side and pull it out side (make sure that your stearing wheel is adjusted at the lowest level)
Then you have to locate the 4 screws holding the cluster and unscrew all four.
After all that done you'll be be abel to see the wires that are going inside of your cluster, but don't worry all you have to do is pull two blue plastic cable heads and you are done!
Get the new cluster and just put back the cables and screw back all six screws mentioned earlier!
Glad I could help and please post pictures when you're done.
Old Apr 19, 2012 | 11:52 PM
ok but a quick question i dont have a tachometer on my current one, do i needa add extra wiring or may i already have it just it isnt being used, cause i want my new speedometer to have the tachometer would it be easier just to buy and install a single tachometer ?
Old Apr 20, 2012 | 06:23 AM
xbesox's Avatar
No, you don't need to add anything! I did it on 3 Civics and one of them was a 97 Civic and the rest were a 2000 and a 99, so it's pretty easy! All you need is the new speedo and a screwdriver.
eqmassa
Jun 21, 2011 04:41 PM
boosted97civic
Nov 29, 2006 12:13 AM
KC4
Apr 28, 2006 03:33 PM
1998wagonhatch
Aug 15, 2005 03:36 PM
millertime17
Jun 26, 2005 09:38 PM
