quik question on valve cover gasket
Old Sep 29, 2007 | 03:16 PM
PREKGSR's Avatar
Default quik question on valve cover gasket
alright so i got some duplicolor high temp paint in red and a new valve cover gasket but do i when i replace the gasket do i have to put any kind of gasket sealer ?
also how can i get that wrinkled finish , i want it to look as oem as possible
Old Sep 29, 2007 | 04:15 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: quik question on valve cover gasket
I would use gasket sealer. I replaced my gasket without the sealer and it had a slow leak, so I took it off and used the sealer and it's fine now.
Old Sep 29, 2007 | 04:37 PM
PREKGSR's Avatar
any idea on how to get that wrinkle finish man?
Old Sep 29, 2007 | 04:58 PM
well with a wrinkle stuff you can try some wrinkle paint and dont put abunch on it.... now IT WONT wrinkle right away.... takes about 1/2-1hour for it to wrinkle but it will wrinkle.... the more paint you slap on it the more/larger wrinkle will be...
and with the gasket if its a new gasket they say you shouldnt need any BUT ive done that before it its always leaked alittle SO lately i just dont chance it... see the worst leaky spots is right in that cam section.... anywhere its not flat or slow turns should be fine... BUT that harsh 90degree humps for the cam shaft on both sides is the trouble some areas that just dont wanna seal right thier in the crack... so i just do a dab in those corners on the head and then put the valve cover with the seal onto it...
i used some HONDABOND.... got it from dealership BUT any kinda sealer should be fine...
Old Sep 29, 2007 | 05:10 PM
PREKGSR's Avatar
cause i just bought a can of duplicolor high temp paint in red but like i said i wan it to look as oem as possible. im in betweem red or black but that wrinkle finish looks so sexy. problem is i have NO IDEA where to get that type of paint here in PR. and and i cant buy off ebay cause they onlt ship it ground
Old Sep 29, 2007 | 05:16 PM
just paint it with the high temp primer.... then use the black wrinkle stuff and THEN go over it again with the red paint and your good...
Old Sep 29, 2007 | 09:08 PM
fivespeed's Avatar
the honda civic service manual i have says to use liquid gasket when you replace the gasket. i painted my valve cover and decided to replace the gasket too, but when i talked to the guy at advance auto when i bought my gasket he said i didn't need to use liquid gasket.
so far, no sign of leaking...unless it's just really slow.
i also used a torque wrench and used the specs in the service manual so that probably helped a little.
Old Sep 29, 2007 | 11:27 PM
WhiteRabbit1021's Avatar
Get some VHT WRINKLE PAINT.
Old Sep 30, 2007 | 05:47 AM
ya some people dont have leaks... BUT quite a few people do... its just luck
but to save a headache just put a dab of sealer around the cam lifted area for security.. and to keep your motor clean...
Old Sep 30, 2007 | 06:34 AM
PREKGSR's Avatar
ORIGINAL: WhiteRabbit1021
i've been trying to find a can but it seems i wont be able to find one here in PR and all the websites i've been to they only ship ground.
