Rims wont fit?
Alright guys well i am trying to put my rims on but i just cant get it to work. These are my rims http://wheelsnext.com/default.cfm?action=dspWheel&MODEL=CUP%2D5&color=BL ACK%20(GLOSS%20FINISH). It said they would fit in the fitment thing but i am just having troubles. It seems like the lugs are too wide to go on the threads or the threads just dont come out far enough. I can get mabe one or two on but then the others cant go on. Do my rims just not fit or should i try getting new lugs or something? This sucks.
Are there eight or four holes in each wheel? Are you positive that they sent you 4x100's? Are your lugs too far apart for the holes, or are the holes too far apart for the holes in the wheels?
There are no pics on that link, and I dont see anywhere that tehy call out the actual bolt pattern
OOOOH, dude you should have said lugNUTS and not just lugs, that definitely helps
No, stock lug nuts will most likely not fit into aftermarket wheels. You can go to Autozone, Napa, etc and pick up the aftermarket lug nuts. They will come with a special adaptor for your lug wrench too, which adds a bit security. Or you can probably order them from the same sight you got the wheels from.
Good luck!
Good luck!
here's what you need mason hope this helps
[IMG]local://upfiles/8815/A58CA58DB7064D97A1EE10191685442F.jpg[/IMG]
[IMG]local://upfiles/8815/A7C1588DD93F422D9A73391239C6B040.jpg[/IMG]
[IMG]local://upfiles/8815/08B8C9BBF4024836B3D178B1CCD3D77C.jpg[/IMG]
sorry for another post yes i had to buy them
[IMG]local://upfiles/8815/003F29E1E5B546F6A29740CB6E15CEEC.jpg[/IMG]
[IMG]local://upfiles/8815/A694F7FDEB644BD0ADE6BA4D9EE307E5.jpg[/IMG]
ladyM08
Apr 14, 2008 01:08 PM
txedomask433
12
Jul 15, 2007 01:57 PM
