what causes this?
Old Apr 8, 2007 | 08:34 PM
ic892003's Avatar
Default what causes this?
im getting a paint job soon and its not in a booth but it is in an enclosed area, im afraid of cracking or peeling or anything like that, wut causes cracking and peeling after paint jobs? also do i have to get my car symanized after the paint job cause i few places said i have 2
Old Apr 8, 2007 | 08:44 PM
ef4life's Avatar
Default RE: what causes this?
peeling and cracking is from bad prep work. not using the right additives or primers in the paint. like a bumper is plastic so it needs a flex agent in the paint in order for it to not crack when something hits it at a low speed or something. then just adding bondo to fill holes etc. bondo cracks and falls out of the repair. bondo should only be used to make the area smooth and hide small imperfections, not to hide dents and holes.
basically it all comes down to useing good quality products, do excellent prep work, and have the person spraying it know what they are doing.
Old Apr 8, 2007 | 08:46 PM
ic892003's Avatar
oo ok thansk for clearing that up, so wut should be used to cover up small holes if bondo is not good?
Old Apr 8, 2007 | 08:48 PM
ef4life's Avatar
how big of a hole? the best way is to weld in new metal to make a solid repair, gring it smooth. and fill in the low spots with a body filler, sand it smooth, prime and paint.
Old Apr 8, 2007 | 08:52 PM
ic892003's Avatar
all i want to be filled in is the wholes under the honda eblems the 2 little small ones, wat should i tell the painter to use for that?
Stimpy
Jun 15, 2006 04:07 AM
Remmy
May 19, 2006 04:04 PM
Ray012874
Oct 12, 2005 10:51 AM
93SiHb
Sep 10, 2005 01:34 PM
DBallard
Feb 12, 2005 09:44 AM
