Wiring halos to a switch??
black to a chassis ground
red goes from the headlight to one side of a switch, and the other side of the switch goes to a +12v constant. just make sure you fuse the wire at wherever you get power from. and both halos can be wired into the same switch
you can get 12 v from either the battery or the ignition harness. you can prolly get the wire colors at the12volt.com
heresa quick diagram
[IMG]local://upfiles/21897/C5B2FD5073E648B2A101708FBFC7CF32.jpg[/IMG]
