1994 Nissan sentra wont's start
Old Dec 17, 2006 | 02:31 PM
thakid's Avatar
Default 1994 Nissan sentra wont's start
my friend's 94 nissan sentra won't start the engine does not even make an attempt to turn but the lights and radio works and i know the battery is only about a year old. can any one give me any suggestions on what to look for to figure out whats's the problem.
Old Dec 17, 2006 | 02:34 PM
Fiirkan's Avatar
Default RE: 1994 Nissan sentra wont's start
Just cause the radio and lights come on doesn't mean it isn't the battery... check that too... if it doesn't even attempt to turn over, i would check the starter too
Old Dec 17, 2006 | 02:56 PM
Ben's Avatar
Ben
It could very well be the battery as fiirkan said. It only takes a little bit of juice to get the radio and lights running, however it takes a considerable amount to get the car to kick over.
Old Dec 17, 2006 | 03:25 PM
SilverSedan's Avatar
yup, test the battery...but before you do, pull off the battery cables and make sure they're good and clean. make sure they're tight when you re-install them. Check the wiring to your starter, and if nothing else works, give it a boost...and while your buddy tries to start it, tap the starter with a hammer. Sometimes its enough to get the starter to kick over...and if it is, drive the nissan to the nearest parts store and buy a new starter!
Old Dec 17, 2006 | 06:08 PM
thakid's Avatar
ok thanks. will check it tomorrow.
Old Dec 17, 2006 | 10:58 PM
Marty's Avatar
sounds like a bad ground connection
Old Dec 18, 2006 | 12:35 AM
hondaracer05's Avatar
From: new mexico, then mt, then alaska, now mt again...
take the starter,alternator, and deven the battery to the nearest parts store(checker/kragen/shucks) whatevers around, and have them test everything, one of those is phucked imo...
Old Dec 18, 2006 | 11:38 AM
riceburner700's Avatar
does it make a clicking noise when you try to start it?
rainydaze
Oct 1, 2012 03:52 PM
TrAvMaNFTW
Dec 15, 2008 12:04 PM
tico2626
Aug 24, 2006 08:56 AM
