ethernet cable cat5 or cat6 ??
Old Sep 17, 2007 | 11:41 AM
civic4ever's Avatar
Default ethernet cable cat5 or cat6 ??
I currently have wireless networking, but for gaming its not so good. You need to have stable connection. Well i have decided to run cable to my computer that is in the basement, and looking what to buy found the CAT5 or CAT6 cables... is there a big diference? or what you guys recommend? thanks for your replies...
Old Sep 17, 2007 | 11:44 AM
My04Civic's Avatar
Administrator
Default RE: ethernet cable cat5 or cat6 ??
usually cat5, no reason to run cat6...cat5 is the normal
Old Sep 17, 2007 | 01:39 PM
Method's Avatar
it doesn't matter which one you get, the only difference between them is how tight it's twisted and how strict it's been made to code. just get cat5E.
Old Sep 17, 2007 | 07:33 PM
StifflersMom's Avatar
Cat Fuсker
no reason to get cat 6 as long as ANY piece of your equipment isn't cat6. You can only get gigabit networking if there is not a single bottleneck on your network.
Old Sep 17, 2007 | 08:19 PM
Sigracer10's Avatar
cat6 is basically replacing cat 5, but theres not much difference. i know at best buy all we sell is cat6 now. if ya already got cat5 just keep using it. if you dont have anything, and you go to the store, most ethernet wire will be cat6
Old Sep 17, 2007 | 10:56 PM
alpeffers's Avatar
cat5e will still handle gigabit, same with cat5, however cat6 is just a higher grade cable and the diehards believe that they will get 0.0001 more fps w/ cat 6, soo they buy it...
generally it will just reduce latency between your computer switch/router... but it is soo miniscule its like less than 5 miliseconds... but if your still running coax... then yeah i'd upgrade
otherwise buy some cat5e that someone's tryin to liquidate cheap
Old Sep 18, 2007 | 07:50 AM
BX_Civic's Avatar
cat5 or 5e is more than fine, i pick mine up at home depot and just crimp the ends myself since im a big PC guy.
xsdudztx
Aug 9, 2007 07:45 PM
spevie
Mar 1, 2005 06:48 AM
LSHatchback
Dec 17, 2004 07:38 PM
88 crex
Oct 24, 2004 01:46 PM
88 crex
Oct 24, 2004 10:01 AM
