My car wont start
After a late night cruisin around my town with my boys. we came home and hit a major pot hole... I was like...."whoa....." Then we barreled out of the car and pounded some twizlers... the pull and peel... and I went out this morning the mutha wont turn over... I tried and tried but it just wouldnt go... any ideas?
RE: My car wont start
V1PER,
Does it crank and not start or will it just not crank at all? What year/make/model is your whip? |
It doesnt do anything..... I just bought the car a few days ago... its a 2002 civic with mad wack power...
ORIGINAL: V1PER After a late night cruisin around my town with my boys. we came home and hit a major pot hole... I was like...."whoa....." Then we barreled out of the car and pounded some twizlers... the pull and peel... and I went out this morning the mutha wont turn over... I tried and tried but it just wouldnt go... any ideas? |
Have you ever worked on a car before?
Did you check the battery leads and ignition? Are you using the right key? Did you grease your muffler bearing lately? |
ORIGINAL: Forty04 ORIGINAL: V1PER After a late night cruisin around my town with my boys. we came home and hit a major pot hole... I was like...."whoa....." Then we barreled out of the car and pounded some twizlers... the pull and peel... and I went out this morning the mutha wont turn over... I tried and tried but it just wouldnt go... any ideas? I sat in car... put key in lock cylinder... turned key... slam fist into dash... said some racial slurs then got drunk |
Does anything electric work like the headlights? If not you probably have a bad connection at the battery or a bad battery. Just last week something broke inside my battery and it went from perfectly working to stone dead. I didn't even hit a bump or anything, it just quit.
ORIGINAL: omniondubs Have you ever worked on a car before? Did you check the battery leads and ignition? Are you using the right key? Did you grease your muffler bearing lately? |
ORIGINAL: mk378 Does anything electric work like the headlights? If not you probably have a bad connection at the battery or a bad battery. Just last week something broke inside my battery and it went from perfectly working to stone dead. I didn't even hit a bump or anything, it just quit. |
Sounds like your car is about as straight as you are
