My car wont start
Old Aug 3, 2007 | 06:14 AM
V1PER's Avatar
Default My car wont start
After a late night cruisin around my town with my boys. we came home and hit a major pot hole... I was like...."whoa....." Then we barreled out of the car and pounded some twizlers... the pull and peel... and I went out this morning the ***** wont turn over... I tried and tried but it just wouldnt go... any ideas?
Old Aug 3, 2007 | 06:23 AM
omniondubs's Avatar
Default RE: My car wont start
V1PER,
Does it crank and not start or will it just not crank at all? What year/make/model is your whip?
Old Aug 3, 2007 | 06:33 AM
V1PER's Avatar
It doesnt do anything..... I just bought the car a few days ago... its a 2002 civic with mad wack power...
Old Aug 3, 2007 | 06:35 AM
ORIGINAL: V1PER
please translate to english so I can help diagnose the problem
Old Aug 3, 2007 | 06:37 AM
omniondubs's Avatar
Have you ever worked on a car before?
Did you check the battery leads and ignition?
Are you using the right key?
Did you grease your muffler bearing lately?
Old Aug 3, 2007 | 06:55 AM
V1PER's Avatar
ORIGINAL: Forty04
ORIGINAL: V1PER
I sat in car... put key in lock cylinder... turned key... slam fist into dash... said some racial slurs then got drunk
Old Aug 3, 2007 | 07:01 AM
Does anything electric work like the headlights? If not you probably have a bad connection at the battery or a bad battery. Just last week something broke inside my battery and it went from perfectly working to stone dead. I didn't even hit a bump or anything, it just quit.
Old Aug 3, 2007 | 07:02 AM
V1PER's Avatar
ORIGINAL: omniondubs
.... not on this car.. like i said i just bought it a few days ago.... I am badley color blind so The leads may be switched any way to tell?
Old Aug 3, 2007 | 07:04 AM
V1PER's Avatar
ORIGINAL: mk378
I my radio works... I was jammin to enya a litttle bit ago... the wierd thing is when i hit the brakes..... my brights come on
Old Aug 3, 2007 | 07:15 AM
omniondubs's Avatar
Sounds like your car is about as straight as you are
