'00 civic running rough only when cold
Old Sep 8, 2005 | 03:04 PM
Scott99's Avatar
Default '00 civic running rough only when cold
Anyone have any idea what this could be? My check engine light is coming (and staying) on. I've tried disconnecting the battery, but the light just comes back on the next day. Also, on a cold start it runs very rough when driving. Acceleration is choppy and it doesn't go away until I shut it off and restart it. Sometimes this doesn't even work. Basically, it has to reach normal operating temperature and be driven for a while. Then I shut it off and let it sit for a bit and when I start it up again its fine. I don't have a code reader but would like to try a few things myself before taking it to the garage. Any help would be great.
Old Sep 8, 2005 | 06:11 PM
97CivicEX's Avatar
Default RE: '00 civic running rough only when cold
Take it to Autozone, they will read the code for free. You have to see what the code is telling you before you go doing any type of blind diagnostics.
Old Sep 15, 2005 | 02:32 PM
Scott99's Avatar
I realize this. However, up here in Canada there is no Autozone or any other place that reads codes for free. I simply wondered if anyone has had a similar problem and could offer some advice before I lose 50 bucks for a diagnosis. So far, PCV valve changed, air filter is clean and wires checked out fine. Next (and little more costly step) is the fuel filter, but I doubt this will do it. Thanx for listening. Scott.
mycam8u2
Jun 11, 2012 09:52 AM
Stumasters
Jan 20, 2008 12:58 PM
apexkeeper
Jan 10, 2007 08:09 PM
