01 Civic Ex cylinder 1 misfire
Old Apr 22, 2023 | 12:31 PM
derpydood3's Avatar
Default 01 Civic Ex cylinder 1 misfire
Replaced sparkplug and coil. Held plug up against head and pretty sure no spark. Not sure where i should be looking next. google results only show 2000 civics with coil packs or coil replacements for an 01 but i know it's not that. swapped coil pack from one cylinder to another misfire didn't move.
Old Jun 1, 2023 | 10:59 AM
Rellyxonald's Avatar
I have a misfire code on one of the cylinders. After doing various diagnoses, it has been definitely determined that the issue is with a bad ground wire on the fuel injector connector on the cylinder with the misfire code. I replaced the entire ground wire for that cylinder with the misfire code from the fuel injector connector all the way to the ECM just to be sure, even though I didn't even see a broken or chewed up wire. This didn't resolve the issue.
192.168.100.1 192.168.1.1
mnelson696
Aug 21, 2016 04:17 PM
carter136
Mar 10, 2010 08:45 AM
AnimalWild
Jun 27, 2008 11:46 AM
rsylvstr
Jan 4, 2007 02:19 PM
tlthehun
Aug 11, 2006 01:35 AM
