03 Door lock not working.
Old Jun 26, 2007 | 05:39 PM
BIMMERGUY's Avatar
Default 03 Door lock not working.
Hi Guys,
My wifes 2003 Civic LX exterior door lock is not working from the outside. I can put the key in the lock, But it will not turn. She locked her keys in the car a couple months back..... Yea... It is possible on a civic. Anyway, When AAA opened it I think he damaged the lock. It kind of worked at first. Now nothing.
Can I replace the lock mechanisim seperate of the Handle? And Will Honda order me one to match the rest of the car based on the rest of the car? If not am I able to swap the Drivers and Pass side door locks?
Thanks.
Old Jun 27, 2007 | 04:55 PM
BIMMERGUY's Avatar
Default RE: 03 Door lock not working.
Anyone?
Old Jun 27, 2007 | 07:39 PM
dfdon's Avatar
take off the door panel and check it out
Old Jun 27, 2007 | 09:48 PM
jeff948594's Avatar
is triple a gonna pay because my first car was an 84 blazer and that was annoying with seperate keys for ign and doors, probably for less than the cost of a new handle you could just buy her a keyless entry system, alarm or remote start system.
Old Jun 29, 2007 | 08:48 AM
chelseadaisy333's Avatar
This sucks.
Why post replies that don't help anybody?
"take off the door panel and check it out "
Old Jul 3, 2007 | 12:37 PM
BIMMERGUY's Avatar
ORIGINAL: dfdon
Thanks for the advise. Being an aircraft mechanic by trade, I have already done that. Using my deductive reasoning, I have concluded that the problem is internal. However, I did not try to disassemble the door lock assembly without having the replacement parts on hand.
Thanks.
Old Jul 3, 2007 | 02:07 PM
jd352's Avatar
ORIGINAL: chelseadaisy333
This sucks.
the reason why no one answers is bc this has already been answered at least TWICE by me since I have been a member. Its called a search button. For the LAST and final time I will ever answer this question... it is your actuator and is a common problem. And it is usually easier to replace the whole assembly.
Old Jul 4, 2007 | 05:15 PM
BIMMERGUY's Avatar
ORIGINAL: jd352
This sucks.
Thanks smart guy.....
I was trying to find out if the left and right lock cylinders are interchangeable. The dealer said if I replace the unit as a whole, It will not have the same key. And I even asked if the could order a matching one based on my vin....
About the search,
I did try a search, But when people use terms like "help" "Now what" and "Broken" etc. as the sole title of a thread, It is not too likely to come up as a response to the search term " door lock assembly" now is it.....
Old Jul 4, 2007 | 07:38 PM
jd352's Avatar
I had up another post when that happened on a dif. forum and got them all confused. My bad. The handel and the lock assembly are two different parts and will not affect one another.What he meant by take off the door panel and check it out... its actually probably the best help anyone could give at this point. Of all the times I have ever used AAA, they never pick the locks, rather use the slim jim method. I would open it up, and see if any rods were knocked loose or bent before spending the money to replacethe lockcylinders.Once again, sorry, but maybe this advice will help you out.
Old Jul 5, 2007 | 06:03 PM
BIMMERGUY's Avatar
I'll play with it this weekend, then post the results. Thanks
Hudson Oliver
Aug 16, 2012 02:38 PM
montevideano
Jun 12, 2010 02:39 PM
Koala
Oct 12, 2007 09:38 PM
custom
Aug 30, 2007 04:16 AM
Eun
Dec 20, 2006 12:40 AM
