07 civc oil pan?
Old Apr 29, 2012 | 09:44 PM
07civic4u's Avatar
Default 07 civc oil pan?
Guys i have an 07 civic, and the bolt that goes into the oil pan of the car is stripped, what do i do? any help will be appreaciated, I tried looking for an aftermarket one, or how do i go by fixing it please help
Old Apr 30, 2012 | 04:34 AM
boiler1's Avatar
Be more specific, threaded studs are used at the oil pan so you can just replace them if they get stripped. Are you saying the part of the stud that threads into the block is stripped and you cant get it out?
Old Apr 30, 2012 | 05:06 AM
I think he's talking about the drain plug. You can try an oversized plug and retap the hole. Otherwise replace oil pan.
If you paid someone to change the oil and they messed up the plug, go back there and demand that they fix it. Stripped threads are not a normal situation.
Old May 1, 2012 | 10:10 PM
07civic4u's Avatar
thank you guys for all the help, well i am actually talking about the drain plug...i was thinking of replacing the whole thing....dont know where to get the part for cheap.....if i decide to have it fix would it be concidered a quick fix and eventually i will need to replace it anyways....thanks
Execut1ve
Feb 6, 2012 07:29 AM
cvcrcr99
Nov 16, 2011 01:55 PM
ic892003
20
Aug 21, 2008 03:40 PM
oilltd
Jun 10, 2008 04:06 PM
