1992 Honda Civic Manual Transmission Problems Diagnosis
Old Nov 10, 2019 | 09:06 AM
SSOARES's Avatar
Default 1992 Honda Civic Manual Transmission Problems Diagnosis
I was on my way home and stopped at a light. When trying to get the car going again
I heard a loud mechanical "pop" and the engine spun but the car wouldn't move. I
pulled it out of the way and tried to get it going - no luck - the tach registers rpm,
the engine runs but won't engage the transmission. The clutch plate and flywheel
are less than 3-yrs old. The throw out bearing is the original one. The clutch slave
cylinder is more than 5-years old.
Any suggestions - THANKS MUCH
Old Nov 10, 2019 | 11:36 AM
StifflersMom's Avatar
Cat Fuсker
A clutch can fail in more ways than just a worn out disk. When you engage the clutch can you put it in any gear with the engine running? Also, are you sure it's not a failed axle?
Koko4
Feb 26, 2013 02:41 PM
tophatmike
Jul 15, 2011 04:24 PM
deejay1272
Feb 3, 2009 08:37 AM
civicmike
Apr 22, 2007 09:31 AM
karney
Jul 31, 2006 04:23 PM
